Stereo Tool 7.43 - Help - FM Transmitter
FM Transmitter section
All the settings to generate a compliant FM signal.
All the settings that are related to the FM signal can be found here, such as pre-emphasis, stereo and RDS encoding, RDS texts, Stokkemask (ITU-R SM.1268) and ITU-R BS.412 compliance and multipath distortion protection.
FM processing is more difficult that normal processing. Because of Pre-emp you often loose highs when enabling the FM processing settings (Composite Clipping helps a lot against this), Stokkemask and multipath distortion protection can have some impact on the amount of stereo separation, and BS412 lowers the level a lot.
Some people prefer to use Stereo Tool only for processing and use a separate RDS and stereo coder. While this works and still gives a reasonable sound, it makes it impossible to use Composite Clipping which gives several dB's of extra headroom for mainly the high frequencies, and features such as multipath distortion protection. If the whole composite/MPX signal is generated from within Stereo Tool, the sound that can be generated is a lot better.
If you are planning to use Stereo Tool on an FM transmitter, please also read FM Output. If you have multiple transmitters and want to synchronize the sound between them, see Synchronize FM transmitters.
General panel
  • Enabled
    Enables FM processing and features.
Pre-emp panel
Pre-emphasis settings.
To reduce hiss on the receiver, FM stations broadcast high frequencies a lot louder, and the receiver reduces this again. If you don't configure pre-emphasis correctly, you'll get a very dull sound that lacks highs. So, if you don't hear enough highs on your FM station, this is where you should look first.
  • Pre-emphasis
    Enables FM pre-emphasis.
    If this checkbox is enabled, processing (Advanced Clipper and Hard Limit output) is done with pre-emphasis.
    If you want to send pre-emphasized output to a transmitter, make sure that Pre-emphasize output is also enabled!
  • Pre-emphasize output
    Outputs a pre-emphasized signal.
    If you leave this disabled and feed the signal to an FM transmitter, the sound will lack highs. Make sure that this is enabled when using an FM transmitter.
    If this checkbox is disabled, processing (Advanced Clipper and Hard Limit output) is done with pre-emphasis, but signal that's sent to the output is de-emphasized, as it would be in an FM receiver. This means that you can hear the sound as it would be on a radio, but the signal is not suitable to send to a transmitter.
    An exception is when the transmnitter performs pre-emphasis, but chances are that you'll get a pretty bad signal because in many cases the pre-emphasis circuit in a transmitter is non-phase linear, and it might not perfectly match the FM specification.
  • Pre-emphasis time
    The pre-emphasis setting for your region.
    For most parts of the world this must be 50 μs, but in the US 75 μs is used. This means that the increment of high frequencies in the US is higher than in the rest of the world, which also means that it is more difficult to broadcast loud highs.
RF spectrum analyzer panel
Shows the RF spectrum as it should look after broadcasting it with an FM transmitter.
The wider the signal is, the more disturbances your signal causes to weaker stations at adjacent frequencies. A wider FM spectrum also increases intermodulation distortion and reduces the received signal strength (beause a larger part of the spectrum will fall outside that range that a receiver is tuned to.) See Stokkemask and Multipath clipper.
  • Calculate RF spectrum (CPU!)
    Enables the RF spectrum display. Uses a lot of CPU power!
Stereo panel
Stereo coder settings.
  • Encode Stereo
    Enables the stereo coder.
    Requires a 192 kHz capable sound card.
  • Pilot volume
    The stereo pilot volume, in % of the maximum level.
RDS panel
RDS encoder settings.
  • Encode RDS
    Enables the built-in RDS encoder.
    See RDS for more settings.
  • RDS volume
    The RDS signal volume, in % of the total level.
    Higher values may improve RDS reception, but may also increase multipath distortion and make Stokkemask compliance much harder.
Drive panel
Composite limiter settings. Use Composite Clipping instead, it works much better.
  • FM composite limiter overdrive
    Controls the amount of composite limiting.
  • MPX Oversampling mode
    Always use 'ALWAYS', unless you're broadcasting an extremely weak hobby signal.
RDS section
The detailed RDS settings.
These settings determine the texts that are displayed on a receiver including dynamic texts such as the current song name, automatic switching to Alternative Frequencies, broadcasting the current time and date and more.
RDS panel
Detailed RDS settings.
  • RDS PI
    The PI code of your radio station.
    The PI code controls things like automatic switching to Alternative Frequencies,. It's important to set this up correctly. Here's why:
    • If you use the same code as another station in your area, you might 'steal' listeners from them (they automatically switch to your station if its reception is better), or you might loose listeners to them in areas where their signal is better. Beside this, this is extremely annoying to listeners.
    • If you change your code at a later time, some radios where your station has been programmed on a preset button may turn the sound off because they 'think' it's the wrong station, even if reception is perfect. Only reprogramming the preset button helps in that case - but no all listeners will understand this.
    PI codes are regulated differently in different countries, please check with your local authorities what you need to do.
    The PI code needs to be entered as a hexadecimal number. The default is FFFF, which means that it should be disabled - but not al receivers adhere to this.
    The first 2 digits of the PI code are a country code, but again, many receivers ignore it. Whatever you do, make sure that the last 2 digits are unique in your area, and that they are not FF.
  • RDS PS text
    The Program Service text (8 characters)
    According to the original RDS specification, the PS text should be static, and its intended use is to display the station name. However, most stations use this text to broadcast lots of things beside the stations name, such as traffic information, phone numbers, even advertisements. Please be aware that certain receivers - mainly in cars - do not display quickly changing texts because it is seen as a danger because it could distract the driver.
    Stereo Tool can broadcast a constant (not changing) text, as is officially mandated by the RDS specification, but it also supports a lot of extra features such as alternating texts, scrolling texts, and dynamically inserted texts such as the name of the current song.
    Note that the RDS transmission speed is very low (at most 22 characters per second), so building up the texts can take some time. Because the RDS signal is very weak, bad reception, especially for (moving) car radios, often leads to missing parts, which means that - even when the reception is good - texts need to be transmitted at least two times to be displayed. Many radios even ignore texts (or portions thereof) that are not transmitted at least two times. This lowers the effective transmission speed to 11 characters per second. So it can take a lot of time before all the texts are displayed properly. The line is also shared between different types of data (RDS PS text, Link error '9043', RDS ClockTime, ...). Stereo Tool's RDS encoder contains an automatic priority mechanism, which lets texts that have just been changed take more bandwidth.
    The descriptions below are valid for both types of texts, although some (such as scrolling) are not useful for RadioText due to the slow transmission speed.
    Many radios can only display a limited set of characters: Basically the letters A-Z (capitals/upper case only!), the numbers 0-9 and some special characters such as /, \, -, < and >. This is mainly an issue for PS texts, because they are also displayed on cheap LCD displays on car radios. So especially for PS texts, only use the characters listed above. (Lower case characters are automatically converted to upper case by all the receivers that we tested).
    Constant texts
    To transmit a constant text, just type that text in the appropriate field (PS Text or RadioText) in the interface.
    The PS Text must be at most 8 characters, the RadioText can be up to 64 characters. Any extra characters are ignored.
    Example:
      POWER-FM
    Alternating texts To show different alternating texts, write all the texts you want to be displayed in the appropriate field in the interface. Split the different parts with a / character.
    Example:
      POWER-FM/88.5 FM
    (Note: The . character will be replaced by a space on radios that cannot display a .)
    By default, every part of the text will be displayed for 5 seconds.
    Changing the timing of alternating texts To change the amount of time a text is displayed, put the requested time in front of the text, as follows:
    • 1.5s:POWER-FM
      Displays the text POWER-FM for 1.5 seconds. When specifying a time in seconds, Stereo Tool will automatically make sure that the text is transmitted at least twice so radios can receive it properly, even if that takes longer than the specified time.
    • 3t:POWER-FM
      Transmits this text 3 times. Stereo Tool will transmit this text 3 times, then switch to the next text. Note that it is possible to use 1t here, but it will lead to bad reception on many radios.
    Example:
      3s:POWER-FM/1.5s:88.5 FM
    Displays POWER-FM for 3 seconds, then 88.5 FM for 1.5 seconds.
    Scrolling texts
    Due to the slow transmission times, scrolling is only useful for PS texts. Transmitting a PS text takes at least (2 transmissions * 8 characters / 22 characters per second) = 0.72 seconds. (For RadioText that's 2 * 64 / 22 = 5.8 seconds, which makes scrolling useless.)
    For left scrolling, add a < character at the front of your text. To scroll at higher speeds, add multiple < characters. Right scrolling is also possible, use > for that.
    Examples:
      <THE BEST HITS IN TOWN
      <<THE BEST HITS IN TOWN AT HIGH SPEED
      3s:POWER-FM/1.5s:88.5 FM/<THE BEST HITS IN TOWN
    The scrolling speed can also be adjusted using timing settings:
      3t:<<THE BEST HITS IN TOWN
    In the previous example, the first and last characters are displayed only very briefly. There are two possibilities to solve this.
    Adding spaces:
      3t:<<      THE BEST HITS IN TOWN      (ends here)
    But it's also possible to specify different timings for different monents of the scrolling. That makes it possible to display the start and end longer than intermediate parts.
    Instead of using just 2s: which sets the display time for every part of the scrolling, different values can be set for different positions.
    During scrolling, the first position is called '1', the second '2' etc. The last position is also known as '-1', the one before that as '-2', etc.
    So what you want is to display positions '1' (start) and '-1' (end) for 1.5 seconds, and everything in between (2 up to -2) should be broadcast 2 times (the minimum for good reception). That can be done as follows: 1=1.5s,2..-2=2t,-1=1.5s:
    Examples:
      1=1.5s,2..-2=2t,-1=1.5s:<THE BEST HITS IN TOWN
      3s:POWER-FM/1.5s:88.5 FM/1=1.5s,2..-2=2t,-1=1.5s:<<THE BEST HITS IN TOWN
    Word wrapping texts
    Instead of using scrolling, you can also use word wrapping. That way you can type a longer text, and the words will all be displayed separately.
    Word-wrapping is enabled by adding two pipe || characters.
    Example:
      ||THIS TEXT IS WORD WRAPPED
    Again, it's possible to adjust the time that a word is displayed:
      1.5s:||THIS TEXT IS WORD WRAPPED
    If a word does not fit on the display (for PS texts if it's longer than 8 characters), the remaining characters are truncated. To avoid that, you can combine word wrapping with scrolling.
    Combining word-wrapping and scrolling
    If you combine word wrapping with scrolling, every word in a text is displayed separately. If it does not fit on the display, scrolling is used to display the whole word.
    Example:
      ||<TRANSMISSION IS A LONG WORD
    Now the scrolling problem from before re-appears: The start and end of the word are displayed only very briefly. This can be solved using the timing settings described for scrolling.
    So, to display the text, every word 1.5 seconds, but if a word scrolls its start (1) and end (-1) should be displayed 1 second, and the parts in between (2 up to -2) should be broadcasted 2 times, that leads to: 0=1.5s,1=1s,2..-2=2t,-1=1s:
    Example:
      1.5s,1=1s,2..-2=2t,-1=1s:||<TRANSMISSION IS A LONG WORD Including dynamic texts
    Dynamic texts can be used to include all kinds of changing information in your RDS texts. For example the name of the song that's currently playing, the current temperature, the weather forecast, you name it.
    Stereo Tool enables you to include this type of data, as long as you can make the text available in a file. If you have that, there are 4 ways of including data from a file into your RDS text:
    • \R"C:\Filename.txt"
      Reads raw (unformatted) text from C:\Filename.txt, converts it to capitals, and inserts it here in the RDS text.
    • \r"C:\Filename.txt"
      Similar to \R, but does not convert the text to capitals. So - if your input file contains lower case characters - chances are that some radios won't display (parts of) the text.
    • \F"C:\Filename.txt"
      Reads formatted text from C:\Filename.txt, converts it to capitals, and parses it as if it were a part of the filled-in RDS text. So any special characters (<, ||, : etc.) are used for formatting.
      Only use this if you know what you are doing, unexpected special characters in the file can lead to unexpected behavior.
    • \f"C:\Filename.txt"
      Similar to \F, but does not convert the text to capitals. So - if your input file contains lower case characters - chances are that some radios won't display (parts of) the text.
    Unless you are doing special things, you should only need \R.
    Example:
      POWER-FM/PLAYING/\R"C:\NowPlaying.txt"
    The texts are read from disk each time when the sequence repeats. So only use a local disk, then everything gets cached. If you use a remote disk, the program might still until it can access it. Do not use a network disk!
    Because of this, there are 10 seconds between the moment when the file is read and the moment when the contents of the .txt file start to be transmitted. To avoid that, place the dynamic part at the start of the sequence - it repeats anyway:
      \R"C:\NowPlaying.txt"/POWER-FM/PLAYING
    Because song names can be long, you'll probably want to use the word wrapping and scrolling trick described above:
      1.5s,1=1s,2..-2=2t,-1=1s:||<NOW PLAYING \R"C:\NowPlaying.txt" ON/6s:POWER-FM
    How to get the name of the current song in a file?
    If you are using Winamp, I recommend the Advanced mIRC Integration Plug-in (AMIP Now Playing) plugin for this. It can be configured to write the current song info to a file, and you can control the formatting of the song info - and which info is exactly written to disk.
    After installing AMIP, configure it (it can be found under General Purpose plug-ins in Winamp). Enable "MAIL Integration", select a file name to write to, and select a format string in the Now playing edit box. %name gives you the name as Artist - Track. %s gives you the name as specified in Winamp (see General Preferences -> Titles), here you can remove the dash (-) if you want to.
    Let's say you want to use scrolling for the entire artist/track name, including the dash. Then the steps to take are:
    • Install AMIP
    • Configure AMIP: Enabled MAIL Integration, make sure that Now playing is set to %name.
    • In Stereo Tool, type something like: 5s:POWER-FM/<<NOW PLAYING \R"C:\amip.txt"
      That's all!
    For other programs, you'll need to find another way to write the current track info to a file.
    Special characters
    As you can see above, some characters have special meanings in Stereo Tool. More specifically, the characters <, >, |, :, / and \ cannot be used normally in a text.
    If you need to use any of these characters, put a \ in front of it. So: \<, \>, \|, \:, \/ and \\.
    Example:
      \<POWER!\>
  • PTY
    The type of program that you're broadcasting.
    Many receivers can automatically search for some type of broadcast, such as a news broadcast. If you don't always broadcast the same type of program and you want to update this setting, make sure that Dynamic PTY is enabled.
    The list of PTY codes is very different for RDS (EBU, used in Europe) and RDBS which is used in the US. The PTY codes are changed when you change the Pre-emphasis time.
  • Dynamic PTY
    The PTY changes regularly.
  • RDS RadioText on
    Enables broadcasting the RDS RadioText.
  • RDS RadioText
    Configures the RadioText text that is displayed on some radios.
    RadioText is a longer (upto 64 characters) text. Not all radios that can receive and display RDS also display this text.
    RadioText can be configured using the same formatting as RDS PS text. Because it takes a long time to transmit the (much longer) RadioText, upto about 5 seconds for a single transmission of the whole text, options such as scrolling are not very useful, and because the text is so long and reception errors frequently occur, it's better to avoid dynamic texts - unless there's a lot of time for each text to be transmitted (at least 30-60 seconds).
  • Windows-1252 input
    Texts are entered using the standard Windows ASCII table.
    Converts special characters, assuming that they are entered using the standard (Windows-1252) character mapping.
    If this is disabled, characters are transmitted unchanged - so then it is assumed that the RDS character set is used.
  • RDS TP
    Traffic Protocol: This radio station broadcasts Traffic Announcements (RDS TA).
  • RDS TA
    Traffic Announcement: Currently traffic information is being broadcast.
    Receivers will switch to this station, even overriding other audio sources such as CD's, USB sticks, memory cards and cassette tapes, and adjust the audio volume. Make sure to turn it off when the announcement is finished!
  • RDS Music
    RDS Music flag.
  • RDS Artificial Head
    RDS Artificial Head flag.
  • RDS Compressed
    RDS Compressed flag.
  • RDS ClockTime
    Broadcasts the current date and time, once per minute.
    A receiver can use this to adjust its clock.
  • RDS Alt Freq {}
    List of upto 25 alternative frequencies.
    Some radios use this list to check which other frequencies to scan for a stronger signal. However, most radios seem to rely solely on the RDS PI.
SCA section
Settings for extra analog audio channels.
On the FM band, it's possible to transmit extra analog audio channels, which can be used for example for audio transmission for the blind, music for stores etc.
These transmissions are normally modulated at 67 and/or 92 kHz. A special receiver is required to receive it.
Please note that broadcasting SCA channels will increase multipath distortion and that the required frequencies are very high for sound cards - the 92 kHz carrier cannot be transmitted completely at all.
SCA panel
The general SCA settings.
  • SCA Channel 1 Enabled
    Enables the 67 kHz SCA channel.
  • SCA Channel 2 Enabled
    Enables the 92 kHz SCA channel. This will not work properly!
  • SCA Channel 1 Volume
    The 67 kHz SCA channel level. Default is 20%.
  • SCA Channel 2 Volume
    The 92 kHz SCA channel volume.
  • SCA Channel 1 Frequency
    The center frequency to encode the SCA Channel 1 Volume SCA channel.
  • SCA Channel 2 Frequency
    The center frequency to encode the SCA Channel 2 Volume SCA channel.
  • SCA channels lowpass
    Lowpass frequency of the SCA channels.
    If this is set too high, other subcarriers such as RDS at 57 kHz (+/- 2.4 kHz) may be affected.
BS412 section
Settings to control ITU-R BS.412 compliance.
In several European countries, FM stations have to comply to a standard called ITU-R BS.412. This standard demands that the total power over any 60 second period is below a certain threshold.
The BS412 limiter in Stereo Tool attempts to achieve this without compromising the audio quality. It does this using 20 different algorithms that predict future input based on previous input, which together decide what to do with the sound to keep it below, but as close as possible to, the threshold.
Despite of this, you get the best result if the input level is already nearly constant. The BS412 limiter in Stereo Tool knows how to handle increased highs due to pre-emphasis and slightly increased bass because other filters respond less to bass (due to ITU-1770). But other changes may cause problems. So try to avoid using the equalizer in the Multiband compressor and Bass Boost too much.
The BS412 graph shows output and filter effect levels in a single graph. The pre-drawn horizontal lines are 1 dB apart, the darker line on top is at 0 dB.
In the graph, you can see lines of different colors: BLACK shows the moving BS412 output level and should be below, but as close as possible to, the 0 dB line. RED shows slow volume changes. In general, it's best if this line doesn't drop below -1 dB - bigger drops can be noticeable. GREEN/PINK shows short-term volume drops caused by the compressor. YELLOW spikes show that the de-esser reduced loud highs. The actual drop of the highs is less than what is depicted here. BROWN spikes show the de-basser in action.
You can see the output for the last 5 minutes, the last hour or the last day. Use the "Large view" button for a bigger display, which also shows the maximum FM deviation at the bottom (top line is +/- 75 kHz, each horizontal line is 10 kHz less).
General panel
The most important BS412 settings.
  • Enabled
    Enables the BS412 limiter.
Input signal strength panel
BS412 input audio level.
  • Input amplification
    Amplifies or attenuates the input level before the BS412 limiter.
    This value should be chosen to amplify or attenuate the audio level such that it is just above the BS412 target level, to avoid stress on the BS412 limiter. Red line drops should be limited as much as possible (preferably no drops below -1 dB) and the green/pink line drops should not get below -2 dB too often, but the black line should be as close as possible to 0 dB.
Target level panel
Deviations from standard BS412 values.
  • Target maximum level (60 s)
    Determines the maximum BS412 output level.
    In most countries where BS412 is mandatory, this must be set to 0 dB, but in some it's +3 dB. When changing this setting, you may also need to adjust Input amplification.
  • Max MPX deviation
    Lowers the maximum MPX deviation when using BS.412.
    If you have a sound card that's not perfectly linear, you can lower this slider a bit to lower the maximum peak level of the output. The Target level will still be reached, so this can be used to protect against 75 kHz overshoots.
    Stations that want to sound smashed can lower this setting further to increase the amount of clipping.
Details section
Settings that control how the BS412 normalization is performed.
Compressor panel
BS412 compressor settings.
  • Dynamics
    Controls the BS412 compressor target level, relative to Target maximum level (60 s).
    Setting this higher means that the compressor kicks in later, but may result in bigger slow volume changes.
  • BS412 Compressor upspeed
    Determines how fast the volume level is increased when the output level is low.
    When the output volume has been lowered due to too loud sounds, this slider determines how fast the output volume can be increased again. A higher value means that the average output level gets closer to the target level, but may also cause pumping. A low value may cause source material with big volume changes to come out too soft on average.
  • BS412 Compressor downspeed
    Determines how fast the volume level is decreased when the output level is too high.
    When the output volume would be louder than the set maximum + , this slider determines how fast the output volume is reduced. A higher value means that drops faster. A low value may cause the volume to be too loud for a longer period of time.
  • BS412 Remove remaining peaks above
    Cuts off remaining peaks above this level.
    The compressor responds slowly, this cuts off peaks that remain.
Slow response limiter panel
Controls the long-term limiter.
The long-term limiter adjusts the level very slowly based on 20 different prediction algorithms that predict future input. If the amount of limiting is less than about 1 dB (visible as a red line in the BS412 output display), it should normally not be noticeable.
  • Volume drop speed
    Determines how fast the volume is dropped if it is too high
    BS412 requires that the total volume stays below a threshold in any 60-second period. If the input level is too high (higher than Target maximum level (60 s)) at any moment, it needs to be dropped. If this is done fast, the drop will be less deep, but for short bursts it will be bigger than needed. If the drop is slow, and the loud sounds last for a longer period of time, the drop will get deeper because the first part which is too loud needs to be compensated. So, if you broadcast audio with rapidly changing volume levels, a lower value (say, 2) might work better, for normal music a value around 3 should be fine. If you're going to broadcast constant tones, go for a higher value :) .
  • De-esser threshold
    Limits loud highs before the compressor.
    Reduces loud (pre-emhpasized) highs before they hit the compressor. This filter only responds if the total level would be too high.
  • De-basser threshold
    Limits loud bass before the compressor.
    Reduces loud bass sounds before they hit the compressor. This filter only responds if the total level would be too high. controls if in case of loud bass the total level is reduced (causing pumping) or only the bass (causing less bass).
  • De-basser pumping vs. bass reduction
    Chooses between bass reduction or pumping.
    If the bass gets above the threshold set in De-basser threshold, this slider controls if the entire volume should be dropped (causing pumping) or only the bass (resulting in less bass).
Headroom panel
Determines how much headroom the BS412 limiter has for errors.
  • Headroom
    The amount of headroom.
    If this value is too low, sudden big volume drops (red line) can occur, which are usually visible as a sharp very deep spike down. This causes a very brief drop in audio level, which must be inserted at that point because otherwise the signal would have gotten above the Target maximum level (60 s).
    However, if you lower this value, the average output level will also be lower (of course, differences of 0.1 dB are not really noticeable).
Stokkemask section
ITU-R SM.1268 compliance settings.
The Stokkemask (ITU-R SM.1268) is a mask on the RF spectrum (see RF spectrum analyzer). Enabling this mask makes the RF spectrum less wide, which improves multipath distortion and reception strength of your station, and reduces disturbances caused to weaker stations at nearby frequencies.
Using Stokkemask is mandatory in the Netherlands, but it improves reception everywhere. For stations that don't need to be compliant but do want the improved reception, Multipath clipper can be used - it has less impact on the audio and the CPU load but it should have the same advantages.
The Stokkemask filter can be used without using Composite Clipping, but the sound quality will suffer a lot, and the effects of the RDS and stereo pilot cannot be taken into account, which means that compliance cannot be completely guarranteed.
Stokkemask (requires Advanced Clipper) panel
Enables Stokkemask clipping mode.
Stokkemask CPU usage panel
Settings that affect the Stokkemask clipping CPU usage and audio quality.
Composite Clipping section
Composite clipping greatly improves the quality of loud FM transmissions.
The composite clipper can create upto 160% left and right channel modulation while keeping the total modulation at 100%. It also allows the usage of Single Sideband stereo coding and several reception improvements.
If the audio is clipped normally, and stereo encoding and RDS encoding are added afterwards, the output that is generated will only rarely peak to the maximum modulation. Multiple dB's of signal headroom are wasted by clipping the audio without looking at the stereo pilot, RDS signal and how the L+R and L-R modulated at 38 kHz contribute to the peak level.
To give a simple example: If there's a high frequency peak in the audio, and both the stereo pilot and RDS signals are peaking in the opposite direction, then the peak in the audio could be clipped at a much higher level. It is possible to 'hide' audio peaks inside the holes created by the pilot and RDS signals. The effect of the 38 kHz modulation of the L-R signal is even bigger but also much harder to explain.
When using normal audio clipping and then adding the stereo and RDS signals, the left and right channel audio level after demodulation on an FM receiver will always be a bit below 100%. FM composite limiter overdrive can get it closer to 100%, but it will never exceed 100%. When using composite clipping, values over 160% can be reached. The audio level coming out of the receiver still won't exceed 100% though, because only high frequencies can reach levels above 100%, and they are reduced with de-emphasis in the receiver.
The composite clipper can not be used if you are using an external stereo coder, and works slightly less good with an external RDS encoder.
Composite clipping (required Advanced Clipper) panel
Composite Clipper settings.
  • COMPOSITE CLIPPER
    Enables the Composite Clipper.
    The composite clipper uses the Advanced Clipper, but uses a lot more CPU load.
  • Extra Composite clipper drive (Extra Composite Loudness)
    Extra Clipper drive (Loudness) when using composite clipping.
    Because the composite clipper causes far less artifacts in the sound, it's usually safe to make the sound a bit louder. This slider allows you to do that without changing the normal Clipper drive (Loudness) level for when the composite clipper is turned off.
  • Composite clipping Strictness (CPU)
    Controls how strictly the clipper clips.
    Lower values leave more small spikes in the output signal, which (if you don't want spikes) need to be removed by HARD LIMIT. And HARD LIMIT removes the spikes by lowering the output level. Strictness is configurable because higher Strictness levels cost much more CPU processing power.
    The Advanced Clipper Strictness (CPU) setting is ignored when the composite clipper is active.
  • Clip demodulated peaks
    Don't allow too high peak levels in demodulated audio.
    Some radios have a problem with very high demodulated peak levels. Without any reduction, they can reach levels over 160%. Since stations can also broadcast with too much (more than 75 kHz) modulation, a radio will always have some headroom - but 60% is just too much for some.
    Such high spikes only occur occasionally, so clipping them at a lower level (110-130%) does no affect the audio much.
    This increases the CPU load. Multipath clipper and Stokkemask have a similar effect (they keep the peak levels at around 120%), so it is probably better to use those.
  • Clip demodulated at
    The level at which to clip the demodulated peaks.
    See Clip demodulated peaks.
  • Also composite clip low frequencies (CPU!)
    Slightly increases the quality of low frequencies, at the cost of increased CPU usage.
    For low frequencies, composite clipping has far less effect than for high frequencies, but it can still have some effect. With this checkbox enabled, the bass clippers also run in composite clipping mode.
  • Performance: Not for pre-clipping
    Uses composite clipping mode for some preparation steps.
    Before the actual clipping starts, a 'test' clip is performed to detect quality issues such as drops in other frequencies caused by loud highs. If this setting is disabled, this test clip is performed at a lower sample rate, which might slightly affect the result of the measurement.
  • Single Side Band (SSB)
    Enables Single Sideband encoding.
    This video was published by Omnia:
    Single Sideband (SSB) coding means that the stereo signal is encoded at the area between 23 and 38 kHz, instead of 23 and 53 kHz. This should reduce multipath distortion issues because there is less high frequency content.
    Reports on the usefulness of this technique vary. Other manufacturers report numbers like 40% see an improvement, 40% see a deterioration, 20% sees no difference.
    For now, if you want to improve multipath distortion, our suggestion is to use the Multipath clipper or Stokkemask - responses to that have been far more convincing. Of course you can also combine them.
  • Type
    Select a single sideband encoding method.
    When using Single Side Band (SSB), there are multiple methods to do it. They all may cause a different result, some were made to resemble what other manufacturers do, others were made based on our own ideas.
    • Standard
      This is how other manufacturers do it. Very low frequencies (upto about 150 Hz) are modulated normally, anything higher than that is modulated only on the lower sideband.
    • Probably optimal
      Something special happens when a tone of 12666.7 Hz is transmitted in the L-R signal. The upper sideband frequency (50666.7 Hz) is exactly a multiple of the lower sideband frequency (25333.3). In the RF spectrum, the energy of these two frequencies gets bundled and much higher peaks occur.
      If you have a tone at 1000 Hz, it will be modulated at 37000 and 39000 Hz. Switching to SSB modulation would create a twice as strong signal at 37000 Hz, which causes much higher peaks in the RF spectrum and seems more likely to cause reception problems.
      Probably optimal mode reduces frequencies above 50667 Hz more, but leaves lower frequencies as they are (dual sideband modulated).
    • Steep optimal
      Similar to Probably optimal, but with a much steeper filter at 50666 Hz.
    • Extreme (Pure Hilbert)
      For testing purposes only, do not use this. Uses perfect SSB modulation. Causes reception problems in receivers and lower audio levels in the clipper.
  • Multipath clipper
    Enables a clipper mode that's intended to reduce multipath distortion.
    Multipath clipper mode combines ideas from a previous multipath clipper implementation and Stokkemask. It probably reduces multipath distortion.
  • Level
    Chooses between more multipath distortion protection and better sound quality.
    A higher value allows more spikes in the RF signal that could cause multipath distortion, but also affects the audio less.
    Because the effect on the audio is already very limited, a value of 100% is usually fine.
