Web interface section Web interface to configure Stereo Tool remotely.
Stereo Tool contains a web server that shows all the Stereo Tool settings in a browser, enabling configuring it from a remote pc, phone or tablet.
Important: At this moment the web interface is NOT protected against unauthorized use. Anyone can get in and change settings. So DO NOT USE THIS on a system with an open internet connection.
Metering is not visible in this interface, so if you can, it's often easier to use a program like TeamViewer to login to the pc remotely. Web panel Setting for the Stereo Tool web interface.
Enable web interface Enables the web interface.
Both enabling and disabling the web interface requires a restart!
Port Web interface port number.
The port number at which the web interface can be reached. To access it, go to http://ip_address_of_pc:port/
So for example, on a local pc with the web host configured at port 8080 you can use http://127.0.0.1:8080/ .
Small buttons Makes buttons in the web interface smaller.
