Stereo Tool 7.40 - Help - Web interface
Web interface section
Web interface to configure Stereo Tool remotely.
Stereo Tool contains a web server that shows all the Stereo Tool settings in a browser, enabling configuring it from a remote pc, phone or tablet.
Important: At this moment the web interface is NOT protected against unauthorized use. Anyone can get in and change settings. So DO NOT USE THIS on a system with an open internet connection.
Metering is not visible in this interface, so if you can, it's often easier to use a program like TeamViewer to login to the pc remotely.
Web panel
Setting for the Stereo Tool web interface.
  • Enable web interface
    Enables the web interface.
    Both enabling and disabling the web interface requires a restart!
  • Port
    Web interface port number.
    The port number at which the web interface can be reached. To access it, go to http://ip_address_of_pc:port/
    So for example, on a local pc with the web host configured at port 8080 you can use http://127.0.0.1:8080/ .
  • Small buttons
    Makes buttons in the web interface smaller.
    Useful for very small screens such as phones.
